LabView 11
I just started working with Version 11. I saw the SSE while trying to build an exe file. I built the program with and without the SSE checked. I am getting an error that I don't understand. Any help?
Philip
(3,956 Views)
Are you getting this error with, or without SSE checked, or with both?
Are you getting this error during build, or later when trying to run the application?
Are you using 64 or 32 bit LabVIEW?
... so many questions 😉
(3,950 Views)
Thanks for the incredible response time. My PC is 64 bit. But I am running the 32 bit application. Both ways the program crashes. I did notice only 3 files in my build folder. The DATA folder was missing? I checked my older versions and I always had a DATA folder?
Philip
(3,946 Views)
(3,941 Views)
