LabView 12 AppCrash
So in essence, this is a System Configuration Issue.  Did the crash happen outside of LabVIEW or while it was running?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 21 of 25
(2,184 Views)
the crash happens while a simple LabView application is running. This app crashes.
Message 22 of 25
(2,182 Views)
I'm very curious... Do your applications use silver controls?  What happens if you use "modern" or "classic" instead?  I haven't ever heard of something like this, so it might be worth investigating.  See if we can treat the ailment instead of the symptom.
Bill
CLD
(Mid-Level minion.)
Message 23 of 25
(2,176 Views)
Hello
I don't use silver style. The controls were from "express" group.
Furthermore, it does not depend on the project. All LabView applications on this machines crash.
I made a simple app to speed up the test time. See attached.
Message 24 of 25
(2,173 Views)
I guess the reason for this crash has to be searched in a combination of hardware, OS and LabView.
Message 25 of 25
(2,169 Views)
