LabView 2012 Windows 10 Network Traffic
We have an application written in LabView 2012 and works fine on Windows 7.  The application starts in Windows 10 Pro without problems but this application extensively uses the TCP/IP stack/Network communication to devices connected locally.  In Windows 7 Pro all we did was edit the firewall rules and the application worked fine, in Windows this does not work.  We have disabled the firewall, added rules, tried the "super admin" account and still having issues.  The LabView application can successfully ping the devices but cannot "talk" to them beyond a ping.  Does anyone have any suggestions besides upgrading to LabView 2015?
Thank You
SD
(3,866 Views)
I am not that familiar with Windows 10, mainly because I don't like it as much as Windows 7 (a different topic for a different day).  But is there some sort of built-in malware program (Defender) or anti-virus software that is preventing the communication?  What sort of devices are you communicating with?  When you say that you can ping them, are you using a System Exec VI within Labview to do that?
aputman
(3,840 Views)
Hi aputman,
To answer your questions:
- there are no malware/av software running
- these are DAQ devices with Ethernet
- we can ping using system Exec VI within Labview and standards windows command prompt command
(3,834 Views)
Have you tried right-clicking the EXE and running as administrator?
aputman
(3,819 Views)
yes makes no difference
(3,815 Views)
Hi SD,
I'm afraid the news is not what you would like.
Please check this link: Windows Version Compatibility with LabVIEW
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,788 Views)
