LabView 2012 runtime engine install problem
@truckryder wrote:
Did you ever get an answer to this?
I am trying to load the 2012 runtime engine on a couple of machines to run a build.
I have seen posts about including it with the application build, but no instructions on how to do that.
when the download starts, it asks for a file name, is there a file name that it requires?
This is an ancient thread...
To include the runtime, you need to build an installer after building the application. Did you try?
Are you also using linux?
What are you downloading when it asks for a filename?
Message 11 of 11
(495 Views)
