LabView 2014 crash while using .Net dll
I am using LabVIEW 2014 with .Net version of 4.5. I have built a program which uses event handler to execute events from .Net dll. When I start the application, it works fine but after some time LabVIEW crash occurs with error 0E0434352. The CLR version used by LabVIew is 4.0. The CPU and memory performance is normal while labview crash.
Kindly help me resolve this problem.
Rashmi
(3,779 Views)
What DLL are you using? Can we see your code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,769 Views)
PFA code for my application.
Four Cam Test.vi is the main vi
(3,765 Views)
