LabView 2017 and Multisim 14.1 Co-Simulation
I recently installed LabVIEW 2017 Developer Suite onto my work computer. I have never used the LabVIEW program before, but have experience using Multisim. I read that there was a way for co-simulation between LabVIEW and multisim. I created the multisim circuit and attached co-simulation terminals to the circuit. However, when I open LabVIEW there is no multisim model option when I select the external models folder inside of the control and simulation functions. Is there anyway to allow LabVIEW 2017 to use a multisim VI? Any help would be appreciated.
(4,040 Views)
Hello Gage,
The NI Circuit Design Suite 14.1 installer shows that the NI LabVIEW Multisim Co-simulation Plug-in 14.1 is supported only in LabVIEW 2015 or LabVIEW 2016.
Gustave
(4,007 Views)
I have labview 2016 32 bit version installed and when I try to run a simulation using a multisim design, I receive this error. Any ideas as to what the issue is, I could not figure it out. error.png
(3,998 Views)
Hi !
Did you installed the version of the NI LabVIEW Multisim Co-Simulation for LabVIEW 2016 ?
(3,987 Views)
