LabView 5.1 support of non-English languages
I need to display the User Interface VIs in 5 European languages: French, Italian, Spanish, German and Portuguese. The problem is with the special characters of these languages.
When I tried to copy a string containing a special character from a normal Word document to a Label in VI, the special character was displayed as ? (question mark)
The same happened when I tried to use import string mechanism. The special characters in the imported strings were displayed as ?.
Doesn't LabView support other languages?
I saw that fonts has style (Such as Times New Roman) size and script which specifies the language.
Maybe I can use fonts which are single language? If this is the solution, can you tell me where I
can find such fonts.
Thanks a lot!!!
(3,012 Views)
Helps to browse through the previous messages in this group...
talia wrote in message
news:101-506500000008000000D6150000-982303670000@quiq.com...
(3,012 Views)
See yesterday's discussion for an answer.
You are most likely copying unicode (M$ sence of it) characters from Word. Try to see it using HEX display option of the string control. If it has 2 bytes per symbol, so this is unicode I think.
Next open exported strings file and check font names in it. Then check fonts actually set for the wrong label. Don't use label, use Caption instead, BTW.
Discover which fonts you are using in Word document(unicode or not). Then you can try to export/save text as an ASCII file. I don't remember which is an exact file type for it in MS Word, Don't using it at all. Then open it in ,say notepad
and try again.
Another way to try is to use non unicode font to format your text and then try to copy it again (depends on Windows)
As a quick workaround you can see if the first byte of symbol is 0 or not. If so, just remove it and you'll get normal english text. If not, you can use divisor number, which will be different for the each language. This is clear from the unicode table (2 bytes). If you'll reach this place, let me know I'll try to help how to calculate it.
Hope that unicode is a reason of this behaviour.
P.S. You can determine unicode by open fonts folder and double klicking to fonts. If you see boxes instead of some groups of symbols, so this is most likely unicode (I don't insist on correctness of this way. On my WinNT box this works).
Sergey
(3,012 Views)
