LabView 7.1 Crash With New Dell Extreme QX6850
I have LabView 7.1 on XP. It logs hundred channels from SCXI, FieldPoints, Serial and USB devices.The VIs had been running well for two years at a Dell P4 but the LabView crashes when switches to a new Dell Core 2 Extreme X9650 (see attachments).
The error message doesn't pop up until the VIs has run for about 3 to 30 hours. The VI still keep recording data into Excel file but all number frozen (unchanged).
I reloaded the XP and the LabView but still the same problem.
Anything incompatible with new computer?
Lin
(2,543 Views)
Hi linlan.  Have you tried setting the BIOS to single cpu/thread mode?  We have seen this cure strange crashes in built 7.x applications.
Matt
(2,528 Views)
