LabView 7.1 - Palm OS v5.2
can i create with the PDA Module and LabView 7.1 a Palm application for the Tungsten T3 Palm(Palm OS v5.2.1) or does LabView 7.1
only support Palm devices with older Palm OS versions?
Greetings
Bernhard
(2,971 Views)
Hello Bernhard,
a found two interesting informations for you. See the following links:
http://forums.ni.com/ni/board/message?board.id=170&message.id=65413&requireLogin=False
http://digital.ni.com/public.nsf/allkb/A27678A81DAAA2C18625713A007B70D2?OpenDocument
http://digital.ni.com/public.nsf/allkb/2EFEF30C8E52168986257091006A9910?OpenDocument
It seems, that you can use Tungsten PDAs...
I can't try it, but I hope these information will help you
Best regards
Dippi
(2,951 Views)
thanks for the information.
That sounds very good.
Greetings
Bernhard
(2,941 Views)
