LabView 7.1 and Vista
We want to use LabView again and have a professional developers license for LabView 7.1 and would like to run this on Vista 64 preferably, otherwise Vista 32. Is this possible and if so can some one please point me to the download?
If we cannot use Vista with this license, can someone direct us to the download for Windows XP SP3 please?
Thank you
(3,879 Views)
Check out:
http://zone.ni.com/devzone/cda/tut/p/id/6893#toc2
Looks like LabVIEW will need to be at least 8.2.1
Also, for reference:
http://www.ni.com/vista/
Note that the hardware you are using (if any) might also be an issue.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,876 Views)
I have not had any issues with LabVIEW 7.1 and Vista, but it is not officially supported.  You may run into some issues.  NI doesn't provide downloads to it's software publicly.  If you have lost the original installation CD's, you may be out of luck, but you can try contacting NI to see if they will/can provide a replacement set of CDs.
(3,871 Views)
Thank you for the responses; this was a major help.
Looks like Vista is not an option. I still have the CD's, can anyone tell me a link for whatever updates would be available for 7.1? I don't know where the patches are located on this site or which ones we are entitled to. Thank you.
(3,867 Views)
You can get the 7.1.1 patch here:
http://joule.ni.com/nidu/cds/view/p/id/674/lang/en
(3,862 Views)
