LabView 7.1
I'm trying to program an output on a usb-6525 using LabView 7.1, LabView keeps telling me its not a NI daq and /or not configured in MAX. I'm running MAX 5.1 and it works when I create a task. ?
Message 1 of 10
(4,676 Views)
Hi there,
It's a little difficult to understand what is happening just from your post.  Can you post your code and a screenshot of the error?  It will help others on the board find a solution for you.
Patrick Allen: FunctionalityUnlimited.ca
Message 2 of 10
(4,663 Views)
I'm not even sure MAX 5.1 is compatible with LabVIEW 7.1.
Bill
CLD
(Mid-Level minion.)
Message 3 of 10
(4,646 Views)
I can almost garuntee that the NI-DAQ version you have installed (MAX5.1 is fairly recient) has no support for LabVIEW 7.1.  What version of NI DAQ shows in MAX?  if it is newer than 8.9 you have a problem.  See the NI DAQ / LabVIEW Compatability matrix here
Hey it is even up to date!  Nice job NI!
Message 4 of 10
(4,645 Views)
http://download.ni.com/support/softlib/system_configuration/5.1.0/readme.html
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(4,643 Views)
I checked the readme and yup, support starts at version 8.6.
Trying to find which device drivers are compatible with LV 7.1 is tricky though.
http://joule.ni.com/nidu/cds/view/p/id/1346/lang/en   -  These drivers are from 2008.11
It took a couple of steps to find out that NI-DAQ 8.7.2 (included in the drivers from 2008.11) is in fact compatible with LV 7.1  See here: http://joule.ni.com/nidu/cds/view/p/id/1087/lang/en
I tried finding out which version would be the latest you could use, but searching for that is very painful.  I would try 8.7.2 and if that works, go with it.
Message 6 of 10
(4,621 Views)
Not that painful pallen, just follow the link in my previous post on this thread. 😄
Message 7 of 10
(4,614 Views)
Now that's funny.  Smiley LOL
You'd think one of my searches would have at least referenced back here.  The matrix never came up for me.
Message 8 of 10
(4,604 Views)
Tags gotta have a few have to get you back to those posts with hard to search links 😉
Message 9 of 10
(4,596 Views)
Thanks for all your support. I'm going to try an earlier version of MAX.
Message 10 of 10
(4,571 Views)
