LabView 8.0 Applications Vista Compatibility
I currently develop LabView applications on a Windows XP / LabView 8.0 machine. Will LabView 8.0 built applications be compatible with Windows Vista computers? I suppose the real question is if the 8.0 or 8.0.1 runtime engine will work on Vista.
(3,447 Views)
This has been asked numerous times on this forum. A search would have yielded the following answer: LabVIEW 8.2.1 is compatible with Vista. LabVIEW 8.0 is not "officially" compatible, though it has been known to work by anectodal reports.
(3,435 Views)
Thanks for your reply. What search phrase are you using? I must be doing something wrong.
(3,426 Views)
"labview 8 vista"
The search engine is flaky at times. You just need to make sure the search scope is set to "NI Developer Zone". Setting to "Entire Site" does not yield anything meaningful. The problems with the search engine have been reported to NI numerous times.
(3,420 Views)
