LabView 8.2.1 and DAQmx Base with Linux
Hey, we use LabView 8.2.1 here with Linux. Recently the new version of NI-VISA (5.0.0) and DAQmx Base (3.4) were released and work with OpenSuSE 11.2. But there is no integration of DAQmx Base into LabView 8.2.1 in the iso file. Is there a possibility to implement that? Thanks in advance, Alex
(2,935 Views)
Hello Alex,
thank you for posting at the National Instruments Forum. It is not possible, to use the latest NI-DAQmx Base Driver 3.4 with LabVIEW 8.2:
NI-DAQmx Base 3.4 supports
- LabVIEW 2010
- LabVIEW 2009
- LabVIEW 8.6.x and
- LabVIEW 8.5.x
If you need LabVIEW 8.2.x support, you have to use NI-DAQmx Base 3.3, this one supports
- LabVIEW 2009
- LabVIEW 8.6.x
- LabVIEW 8.5.x and
- LabVIEW 8.2.x
It is not possible to add LabVIEW 8.2.x compatibility to NI-DAQmx Base 3.4. I hope, this clarifies the version compatibility.
Best Regards
Marian Vorderer
(2,908 Views)
