LabView 8.5.1 where to download niScope files
Dear NI support,
during the trouble shooting process for th PCI 5105, LABview ( I guess during
installing new drivers), deleted some standard VI's that are needed for one of
our VI's.
Where can I find a download for following files for LABview 8.5.1:
niScope Close.vi
niScope Multi Fetch WDT.vi
niScope Fetch (poly).vi
niScope Initiate Acquisition.vi
niScope Configure Trigger Edge.vi
niScope Configure Trigger (poly).vi
niScope Configure Horizontal Timing.vi
niScope Configure Vertical.vi
niScope Initialize.vi
niScope trigger coupling.ctl
niScope trigger slope.ctl
niScope trigger source.ctl
Thank you
(3,323 Views)
Hi Philipp88,
It is possible that you do not have the NI-SCOPE drivers installed on your system.  You will need this driver to access the functions you are looking for.  With LabVIEW 8.5.1, the newest version of NI-SCOPE that you can use is version 3.8.  I have included a link below to the download page.  Please let me know if you still encounter issues in finding the NI-SCOPE functions after you have installed this driver:
NI-SCOPE
| Zach J. | Systems Engineer, HIL and Test Cells | National Instruments |
(3,299 Views)
Thank you. It works with these files
(3,288 Views)
