LabView 8.5 and the MATCH PATTERN funtion - Crashes
Since LabView 8.5 my VI's always crash the whole LabView if i do a MatchPattern and then
use the string at the AFTER MATCH output in a Loop. I attached a VI who doesnt really
have a fuction, but it crashs when i run it. I tried to build a application and run it on a PC with
just the RunTime installed, it crashs too.
If i replace the MATCH PATTERN with a MATCH REGULAR EXPRESSION it works fine :S
(3,024 Views)
This was reported to R&D (# 4CJFKTCS) for further investigation. Another possible workaround (besides the one you mentioned) is using Shift Registers in place of the Feedback Node.
Thanks for the feedback!
- Christina, LabVIEW R&D
Christina Rogers
Principal Product Owner, LabVIEW R&D
(2,990 Views)
I saw this too with a while loop and a match pattern looking for <CR>.  I also saw it with search/split string function.
John
(2,876 Views)
Hello John,
If you can create a simple VI that shows your crash and post it here, it would help us verify that we've fixed the root cause of the issue once it's fixed, or see if there is a separate issue to be investigated here.
Thanks!
(2,843 Views)
These VIs crash labview 8.5 on my computer.  The search/split string example is odd, I know, but it illustrates the crash.
John
(2,830 Views)
