LabView 8.5 ring control value precision
Hello everyone-
I'm trying to set up a ring control to select from a list of constants based on a descriptor- in this case, photodiode efficiency constants based on source wavelength.  My constants are on the order of 0.001 to 0.01; each has seven significant digits.
When I enter them into the "Value" field in the ring properties box, LabVIEW truncates down to 6 decimal places.  For example, 0.00998598 becomes 0.009986 whether I enter is as 0.00998598 or as 9.98598e-3.
I COULD put in a number in the range it will accept and multiply by an external factor, but that seems a stupid and unnecessary workaround.  Is this numerical truncation a "feature" or a bug?
Mike
(5,172 Views)
I see what you are saying in LV 8.5.  I would vote bug.  It seems that the dialog box should allow any value to be entered that is within the limits of the data representation selected for that control.  So if the control is set for DBL representation, it should allow a value beyond the 6th decimal point.
I think a possible work around would be to use the property node of the ring to set the strings and values[] to what you want.
Message Edited by Ravens Fan on 11-14-2007 05:28 PM
(5,165 Views)
Have you tried converting your table of constants into an array of strings and then feed the array to the "strings[]" (not value ) field in the ring properties box ?
(5,164 Views)
Try populating your values using the "strings and Values" property. I think it is only an input bug in the properties dialog box.
Use use this code once, then delete it from your main program.
Message Edited by altenbach on 11-14-2007 02:41 PM
(5,154 Views)
Is there a CAR for this?
(5,106 Views)
This was reported to R&D (CAR #4FK5F2R0) for further investigation.
Roy
(5,080 Views)
For searchability:
This was reported to R&D (# 4FK5F2R0) for further investigation.
Brian Coalson
Software Engineer
(4,974 Views)
