LabView 8.6 Software installation error code -32
I have at this time Labview 8.5 on my computer and I'm trying to install 8.6 upgrade from DVDs.
When the installation is beginning, I have the following error:
Error: A file, directory, or other piece of data could not be found (Error code -32). Can you help me to solve it? Thanks, Pierre
(4,208 Views)
hope this helps:
http://forums.ni.com/ni/board/message?board.id=170&message.id=407980&query.id=1079596#M407980
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,204 Views)
Accepted by topic author pierreh
Cheers, This was very helpfull.
The way to solve this error is so to copy DVDs on the hard drive and then install LV from these folders!
(4,187 Views)
