LabView 8 online evaluation connection fails
I'm trying to use LabView 8 online evaluation. All other items are fine except for connection, which always fails. I don't know what the problem could be: my web security or your sever?
Thanks.
Flofish
(3,020 Views)
I am not sure what you mean by "connection". Have you been able to download the evaluation version correctly but are not able to use it? Or you haven't even been able to download ? Please elaborate.
Ankita
(3,005 Views)
When I try to use the LabView 8 online evaluation at
http://labview.ni.demoservers.com/UserReadiness/
I got the following, and I cannot pass the connections.
Supported browser
Passed
Frames Passed
Scripting Passed
Cookies Passed
Embedded content Checking... (ActiveX or Applets)
Connections Checking...
Bandwidth Passed
Thanks.
(2,996 Views)
Did you donwload and install the activeX control? Maybe you need to lower your security settings for the test?
(2,992 Views)
Yes, I have installed that, and that's why ALL other items passed, including Embedded content, which requires ActiveX. I used low for my security level, but it still doesn't work. Also, about the warnings:
  • A Java pop-up titled "Warning - Security." If you see this pop-up, click Yes to close it.
  • A Windows warning about firewall blocking. If you see this pop-up, click Allow to close it.
I don't see them pop-up. So, I really have no idea what's going on here.
Thanks for you help.
flofish
(2,979 Views)
