LabView BUG: Created EXE too small
I see often (5 / 20 ?) the BUG, after creating a LV Application over Application Builder.
The application EXE is created, but is very small.
No error occured while creation of the exe.
LabView: 2014 (2014.0f1  32bit)
Application (EXE) size: is 80kb,   should be ~ 30MB
The screenshot of the crash on the target machine: (see attached)
BR
E.Wiebe
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(3,635 Views)
Eugen,
why is the EXE 30MB at all? This seems really HUGE for an EXE.
Nevertheless, i am not aware of such an issue yet. Does it happen in a specific project or is this more a general issue (read: affects multiple projects)?
Do you reset (read: delete/remove all files in) the target build directory?
Norbert
Norbert
Expert: Geometry
(3,620 Views)
Yes, it is a BIG project:
* Main GUI
* Several Subpanels (injecting Sub-Panels into pain panel)
* Driver Manger
* Drivers (DAQmx, CAN, Powersupply, DMM ...)
* Service Panels (for manual stepping)
* Database Tools
* Test-Classes (main with childs) for testing several products
No, I do not delete all files from target dir.
BR
E.Wiebe
Eugen Wiebe
Bernstein AG
(3,597 Views)
Eugen,
and what happens if you do delete the files?
Please note that you have to take care of support files (e.g. error-txt) as well....
Norbert
Norbert
Expert: Geometry
(3,585 Views)
