LabView - Can't use it after saving
I am new to labview and am trying to understand what's going on. I am using version 2009 (Professional) 64-bit with Windows 7 Pro 64. Basically, after I save the file, those little dots at the end of the objects that allow you to draw wires disappear and I am unable to draw wires on a saved file, but before saving everything works fine. Can you explain if I am missing something here? Thank you.
(2,863 Views)
You mean you can no longer wire to objects on the diagram because the connectors don't show up? Could it be you disabled the auto-tool?
How does "saving" fit into all this. Do you keep the VI open, press save, and problems start? Do you save and then reload from disk?
Can you show a picture and maybe attach a small VI?
(2,856 Views)
