LabView Class Errors causing LabView crashes
I have had consistent issues with LabView crashing i.e. LinkObj.cpp line 710 when errors exist within a class, or a class location changes.  I try to reuse code, move classes from one project to another, add and delete classes in projects as projects require different objects.  Every time I perform these operations, I get a LabView crash.  I do not see any other issues like this listed in the knowledge base or anywhere else.  Does anyone else have these issues?  This has occurred ever since LabView classes were intiated, and is still present in LV8.6.
(3,125 Views)
Hi ogrant,
Thank you for the information on this error. It would help if you could provide the code that you are using and any information to help reproduce the error so that I can report this to our R&D department. Also, if you get a message when this occurs asking you to report the problem to National Instruments, it would help if you could report it and send in the log file that creates. Include the title or address for this post in your comments if you send that information in.
Stephen S.
Applications Engineering
(3,104 Views)
I have sent this to the Eng Dept.  This last time (yesterday), I had to get the software back up and running, so I had our IT department restore from tape so that I can meet deadlines.  I was not able to save the offending project.
(3,102 Views)
