LabView Code Application
Can I use same LabView code for several experimental setup at a time using one computer?
TIA
(2,739 Views)
Accepted by topic author Chowdhury_Milon
If hardware is involved, you might run into issues if multiple instances are trying to talk to the same instrument.  Otherwise you should be able to set your VIs to be reentrant and multiple instances can be called at the same time.
(2,732 Views)
