LabView Community Edition 2021 activation issue and workaround (downgrade to 2020 SP1)
the title says it all: I have not been able to activate the 2021 version, despite following all the suggestions posted on the forum (e.g. deactivating ipv6, firewalls, and switching networks). I only managed to get an installation working by deleting everything and installing the 2020 SP1 version.
posting this for others with the same issue (also see https://forums.ni.com/t5/LabVIEW/LVCE-activation-issue-again-despite-following-all-forum/m-p/4173596...).
Best,
tb
(2,883 Views)
Please elaborate: 1. What do you mean by "delete everything"? 2. As for the final result did you manage eventually to activate the 2021 version or had to settle for 2020SP1? I have 2020SP1 installed and working but can't activate 2021.
(2,863 Views)
Same problem here. I have the 2020 SP1 community edition installed and activated and working fine. Just installed the 2021 community edition but cannot activate it.
(2,798 Views)
Accepted by topic author tb000
with "delete everything" i meant "i used the package manager to remove all installed packages" prior to installing the 2020 SP1 version.
I have not managed to activate the 2021 version in the end. I settled for 2020 SP1.
(2,791 Views)
