LabView Community Edition
Greetings. I recently installed Labview [Community version] on a laptop running the latest version of Windows 10. Aside from LabView, another program was downloaded and installed unintentionally - JKI Dragon. I do not understand the degree/nature of inter-dependency between the two programs.
Perhaps I will need Dragon at a later time, but I would like to separate the two and use just LabView for now. Is this possible without removing both and reinstalling just LabView?
Your thoughts are solicited. I am not expert with software, but I did expect that installation and initial use would be within reason.
(1,552 Views)
Hi
It is possible to install LabVIEW without installing JKI Dragon, you just remove the tick in "JKI dragon" in the suggested extra installers windows come during installation.
I am also quite sure you can also uninstall JKI Dragon in NI Package Manager without uninstalling LabVIEW.
Anders Pedersen Sekanina
sekanina.dk
(1,489 Views)
As Anders hass written, you can uninstall JKI Dragon from NI Package Manager:
(1,471 Views)
You probably installed many components you will never use. That's fine, you can just open LabVIEW and get started without worrying about that.
(1,469 Views)
