LabView Crash
We installed the LabView7.0 on Windows XP pro.
After we run the application and upon exit from LabView itself we are getting the error message saying:
The instruction at "0x64480386" referenced memory
at"0x00000004" . The memory could not be "read".
It never happened before on Win 2000 or NT.
What could be wrong?
(3,154 Views)
Hi
I once had a similar error message with a crash. The problem was solved by updating DAQmx
to the latest version. Also check the other drivers and download the latest versions even
if you don't use them in your application. The driver updates often contain fixed bugs.
Greetings
(3,125 Views)
Hi Canadian,
If you search for "the instruction at" among the KnowledgeBases (www.ni.com/kb), you will find this KB that might help you solve your issue:
LabVIEW Application Error: The instruction at "[address x]" referenced memory at "[address y]". The memory could not be "read". [link removed; article no longer available]
Let me know if you have any luck with nailing the issue, thanks.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(3,095 Views)
