LabView DAQ card programming
I have recently started using an NI USB-6211 DAQ card on my laptop. I have the driver software installed and the DAQ is working, but when in LabVIEW main package, I dont have any functions in measurement tab or express tab to use to control the DAQ . I would appreciate some help 🙂
(4,219 Views)
Did you install the DAQ drivers after installing LabVIEW?
(4,207 Views)
yes i have labview with a couple of months but only recieved the daq card recently for a new project
(4,202 Views)
I'll ask again.
Did you install the DAQ drivers AFTER installing LabVIEW?
What version of LabVIEW and what version of DAQ drivers did you install?
(4,181 Views)
yes i installed labVIEW before the DAQ drivers, the version of labVIEW i have is 2012. The version of driver is NI-DAQmx 9.1.7.
(4,160 Views)
Accepted by topic author Liamostudent
That version of DAQmx is not supported with LabVIEW 2012.
Try download the newest driver, version 9.7, http://joule.ni.com/nidu/cds/view/p/id/3811/lang/en
(4,152 Views)
yep worked thanks very much!! 🙂
(4,144 Views)
