LabView DAQ running more stable under Linux?
Harry -
Here is an advisor configuration that I built for a system like this : CR2496371.  You can plug it in at ni.com/advisor under Retrieve Configuration.
The minimum requirements for software would be LabVIEW Full w. App Builder (or just LabVIEW Professional) + the LabVIEW Real-Time Module.  You probably noticed after some research, that these chassis are equipped with an FPGA in the backplane as well which can add extensive capability and truly deterministic execution and speed.  However, if this really isn't a concern or priority you can run the cRIO systems in "Scan Mode" where you won't have to program the chip.  If you do decide to program the FPGA that will require the LabVIEW FPGA Module in addition to the software mentioned earlier.
So...
No FPGA programming:  LV + App Builder + LV Real Time
Yes to FPGA:   LV + App Builder + LV Real Time + LV FPGA
Ben N.
Applications Engineering
ni.com/support
Message 11 of 24
(2,941 Views)
i have had LV apps running under Windows for over a year without rebooting.
If your apps is crashing under Windows I would first ID the nature of the problem. Converting to Unix or a RT target could cost a lot of time and effort only to find out you still have the same issue.
"Upgrading your engine will not fix the flat tire."
Ben
Message 12 of 24
(2,939 Views)
Hello Ben,
Smiley Wink I am working on my flat tire but also hoping my old man can buy me a new engine! haha
I did find there is a slowly memory leak in my code and right now I am trying to narrow down where they are. I researched a little bit and learned from others that two main causes of memory leak:
1. Building array inside loop
2. File IO without proper closing it.
For item 1, I do have arrays built inside a big while loop, but I havn't figure out how to get around it yet. Forgive my ignorance, but is there any easy way to resolve this?
For item 2, I found I forgot close one data file aftering writing to it. I fixed it and havn't got chance to test it.
Do you have any other suggestions? What else I should look for to resolve the memory leak issue? I know there are many discussions on this but am trying to use the simple method first to see if I get luck...
Thanks for your help!
Rgds,
Harry
Message 13 of 24
(2,935 Views)
Search on "inplace" at the very least.
I have writtein many posts on the subject and it is no easy topic to cover quickly.
If you narrow down the leak and are still stumped post code pluse images and we (the team here) may be abel to focus on what is hitting you.
Ben
Message 14 of 24
(2,933 Views)
Hi Harry.
Also worth mentioning: The "NI LabVIEW Desktop Execution Trace Toolkit" should be helpful in identifying memory leaks (and other issues).
And I agree with Ben: We also have LabVIEW applications running at our customers for more than one year without facing any issues. I have to set the limit of one year because our customers usually request new features in these applications about once per year. Then they stop the "old" application and replace it by the update. And then, run for about another year ... No need to blame any operating system nor LabVIEW.
Regards Guenter
Message 15 of 24
(2,915 Views)
Thanks Guenter.
I checked this Desktop Execution Trace Toolkit and it costs ~$1000 so I probably have to relay on "manual" approach to identify the issue. But I do think you, and also Ben, are right about it's probably my program's fault. I'll try to dig in a bit more...
Thanks again!
Harry
Message 16 of 24
(2,914 Views)
Ben,
Thanks. I'll see if i can find it out myself. If I cannot, I'll for sure ask for help from your experts!
Rgds,
Harry
Message 17 of 24
(2,911 Views)
@Guenter Mueller wrote:
Hi Harry.
Regards Guenter
Quick war story. A phone call from my customer...
Cust: Ben, I got a message indicating we are running low on memory, do you have any ideas?
Ben: What does the event log show?
Cust: Nothing unusual but there are a lot of entries.
Ben: How long has it been running?
Cust: The log shows about 18 months.
Ben: I may be time to try restarting the application to open a new log file.
That application ahs been running 24 X 7 since 2001 with only occational rebots or restarts to let me add new features. If you have ever worn a protective mask with disposable cartidges, on the side of those cartridges is a sticker earned by the app I mentioned above. See here  (wanring, this is link to cdc.gov) for some of the testing that LV has been driving behind the scenes for years.
Sorry for the [OT] but I do want to squash the diea that LV is not stable.
Take care,
Ben
Message 18 of 24
(2,898 Views)
Nice story, Ben.
It's time to rewrite your application and discard very old entries in the logile Smiley Wink
This would take it to the next level ...
Guenter
Message 19 of 24
(2,893 Views)
Nice story, Ben.
Guenter
Smiley Very Happy
Or just opening a new file every year or so... Smiley Wink
Ben
Message 20 of 24
(2,891 Views)
