LabView Enviromental Chamber Help
I am using LabView to run an E2 environmental chamber. I was wondering if anyone had an idea of how to set up the block diagram in a way that would increase pressure to a certain target, hold at the target pressure for a duration, and then release the pressure.
(3,059 Views)
The easy answer is yes.  I know several ways to get LabVIEW to count up, pause, then count down.  If you need a more detailed answer than that, you need to provide more information.  What are your requirements? What kind of hardware are you using? What have you tried already?
(3,005 Views)
It seems like it is the answer for many questions, but look at state machine architecture.
(2,986 Views)
I do not see anything on an E2 chamber, do you have the model number and manufacturer?  We use Thermotron chambers and can remotely access them over TCP communications.  You would just need to know the command set used by the chamber and as long as there is some remote control connection (GPIB, LXI, USB, RS-232,...), it should be fairly straight forward from there.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,978 Views)
