LabView + Excel Macros
Hello all,
So I have successfully been able to read in data from the DAQ and populate the important cells in Excel. And the data in those cells are continuously being updated since the while-loop is in place. My next challenge is to try and run the macro in excel that with the populated data present. When I try with the following set up, it constantly imports the code to the spreadsheet, does NOT run the code, and does NOT remove the code. I attached the images of my set up and of the error code that I get.
I already changed the Excel Trust Center Security Settings to enable all macros.
Any thoughts?
Message 1 of 1
(2,346 Views)
