08-17-2005 01:12 AM
Dear All,
Thank You
Jegan.
08-17-2005 02:27 AM
How you are providing the excel file path. is it absolute path or is it relative.
if you are using path relative to any one of your Vi then you should strip path for one more level(inside exe only).
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
08-17-2005 02:58 AM
08-18-2005 11:32 AM
09-19-2005
01:57 AM
- last edited on
08-13-2026
10:16 AM
by
Content Cleaner
Hi Jegan,
Try this link https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019O6PSAU&l=en-US
Elad
09-19-2005 06:06 AM
03-26-2014 11:50 AM
I am using the Application property nodes and invoke nodes to open an Excel spread sheet and log data from my LabVEIW 2012 program on a Win 7 Pro system. Everything works great running my VI in LabVIEW. However when I create an application exe using Application builder, The Excel File open dialog runs, opens an EXCEL spread sheet but not data form the running exe ever gets populated into the XL sheets and no errors are indicated form the program. If running the same program in LabVIEW, I get an error message if the Excel file fails to open or I try to write data to a bad XL Cell.
What is going on? Is there another run-time engine addin that must be installed on the target PC to get the app.exe to properly interact with XL on the target PC?
