LabView FPGA Veristand Project Missing dll's
Im using the Veristand FPGA add-on and XML builder to create an FPGA personality to run on Veristand. I've now got a new laptop and although I believe I have all the software and drivers required I'm getting the following when I am trying to open an FPGA VI.
Labview cant find the following .NET Assembly Named
  • "NationalInstruments.Veristand.SystemStorageUI.dll"
  • "NationalInstruments.Veristand.SystemStorage.dll"
  • "NationalInstruments.Veristand.SystemDefinitionAPI.dll"
Can anyone point to where I can find these or what I may be missing from the installation?
Dave
(3,695 Views)
Hi Dave,
After dropping down the XML Builder in LabVIEW I have also experienced the same issue. Did you manage to find the SystemStorage.dll ?
HPT
(3,583 Views)
Figured it out... missed out the Config File step on the installation instructions (doh!). Lesson learnt: read the instructions carefully before starting!
Just to make the solution explicit... unzip the Config File and copy into C:\Program Files (x86)\National Instruments\LabVIEW XXXX then run the VIPM installation.
HPT
(3,582 Views)
