LabView Installation Bug
Hi all,
I was told by Mathworks support that LabView writes registries that incorrectly use the Flexlm license manager and would cause problems with any other application that does this.  I don't want to have to dump LabView, so can anyone confirm this?  This is the email I got:
-----Original Message-----
mailto:support@mathworks.com]
Sent: Wednesday, September 28, 2005 12:17 PM
To: Bold, Jason (ALPE)
Subject: RE: Starting up issue
Please remember that Flexlm is not our product and that many programs use it to manage licenses. If NI has chosen to put this value in the registry it will cause an error not only with MATLAB but any other product which uses Flexlm. My suggestion would be to contact NI for a fix or continue to use the -c in your startup icon.
If you have any further questions, please do not hesitate to e-mail me back. Please be sure to keep the Thread ID included at the bottom of this email intact when replying to this message.
Jason Kuter
Installation and Licensing Specialist
The MathWorks, Inc.
508-647-7000 option 5
Sent: 2005-09-28 01:09:38 PM
To: t-support@mathworks.com
Subject: Starting up issue
There is an entry under HKEY_LOCAL_MACHINE/SOFTWARE/FLEXlm License Manager/NILM License Manager.
It has several entries under C:\Program Files\National Instruments\Shared\License Manager\<TBD>
Where <TBD> is "Licenses", "\Bin\mgrd.exe", "\Bin\mgrd.log"
And last but not least one entry that is simply "NILM License Manager"
without the directory. Is there a known conflict between National Instruments Labview (which is what this is) and MATLAB?
Jason
FI ---> PI > E
Sent: Wednesday, September 28, 2005 9:51 AM
You can search your registry for Flexlm (run regedit from Start-->Run) to see if there are entries pointing to other license file locations.
The fact that -c works means that there is another Flexlm application causing the issue. If you are unable to find an environment variable or registry entry then you will have to continue to launch with the shortcut which points to the correct license file location.
Jason Kuter
The MathWorks, Inc.
(2,678 Views)
This is a known issue.  Please see document ID# 2XTABK9P.
(2,673 Views)
