LabView Keithley
Dear NI Community
I am trying to control my Keithley 2401 using LabView programme. I want to give a current of 1E-6 (similarly a voltage) to Keithley from LabView itself. It's showing Header Error. I dont know where I have made the mistake.  I will be grateful if you all could help me in this regard. I have attached the code below.
I am using GPIB driver.
Message 1 of 9
(2,169 Views)
Most forum members do not have the latest version of LabVIEW. Please save your VI in the previous version, preferably 2019.
Are you using Keithley 2400 SourceMeter - Instrument Driver?
https://tmesystems.net/
Message 2 of 9
(2,126 Views)
Yes I am using that driver.
Regarding LabView, I am using the free community edition.
Message 3 of 9
(2,116 Views)
It doesn't matter what LabVIEW edition you are using. You need to Save for a Previous Version for us to open your VI.
Message 4 of 9
(2,089 Views)
Please check the below files
Message 5 of 9
(2,082 Views)
Most of us won't have the Driver either. And, some of us post with a phone.
Can you inline the image as a snippet?  From the Block Diagram menu click Edit>Select All (ctrl+A) then Edit>Create Snippet from selection.
Message 6 of 9
(2,073 Views)
Please find the picture attached
Message 7 of 9
(2,057 Views)
He's not actually using the Keithley driver.  Just a simple GPIB write and read.  Works fine for me.
OP, what error are you getting?
BTW, you should ALWAYS turn an SMU output OFF before you end your program.  The 2401 can't hurt you too bad, but its big brothers sure can.  Safety first!
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 8 of 9
(2,045 Views)
 I added an Error Out and cleaned it up for the snippet.
These are the results from run where nothing is connected to my 2401.
Message 9 of 9
(2,044 Views)
