LabView .NET callback bug?
I'm running LV2018,
and I'm currently forced, once I run my program, to restart the whole Labview if I want to edit my subVIs (the main VI remains editable): the subVI run icon' arrow changes to an arrow with a thin border around it, and nothing I tested from the board suggestions changes this (ctrl-m, change in the VI properties...)
I discovered here that it could be a known bug (the program I'm modifying uses in fact .NET), but the suggested workaround doesnt work for me...
Do you happen to know if this bug still exists in LV2018, and if there are different workarounds? It's really a pain to restart LV at each test run!
Message 1 of 19
(5,974 Views)
How does this not work? there are errors, or something else?
I do not have LV18, but yesterday I solved a similar problem on LV16 and just checked that in LV 17 this method also exists.
Message 2 of 19
(5,961 Views)
quite simply, it runs and exits silently,
and returning (or re-opening, it's the same) to my subVI, it's still un-editable!
Message 3 of 19
(5,944 Views)
Show your example (in LV16/17)
Message 4 of 19
(5,939 Views)
ouch... as I said in a previous post, it is a rather big project! - not mine, but by the camera's producers (Thorlabs).
I include the two routines I'm working on (TLSC is the main, OnImageFrameAvailable the subVI that becomes uneditable)
The whole project is free to download here link
P.S. I hope it works on LV16/17 - I'm running LV18
Message 5 of 19
(5,935 Views)
Please, use file->save fo previous...
I can't open this files in LV16/17
Message 6 of 19
(5,931 Views)
here they are, sorry...
Message 7 of 19
(5,922 Views)
Without drivers for camera I can't run it, but I don't see garbage collector in "close" case.
Try place my vi like here
Message 8 of 19
(5,918 Views)
that was my mistake, I understood from the workaround page that you could do it in another VI (1. Drop an invoke node in an empty VI...  ).
I put it where you said and I'm halfway there:
- if I put a breakpoint and step in the "close" case, on the unregistering process, then on the GC, then continue, at program's end my subVI is still editable!
- but if dont break&step, it behaves like before: un-editable
very confusing
Message 9 of 19
(5,912 Views)
Looks like your "finish" VIs need more time, but works at background.
When you use Step into, VIs have enough time.
Try to set long "wait" before GC.
If if will help, you need to check driver's status before finish work (and call GC)
Message 10 of 19
(5,905 Views)
