LabView Plotting the Same Waveform Twice
Hi, I was using the Continuous Measurement and Logging Template (DAQmx) and I made some modifications for it to also read from a serial device.
Now for some reason, LabView is plotting the analog input data twice on the same waveform (See "Upstream Pressure" graph in attachment). Is there a way to remove this?
Much thanks,
Ben
(5,071 Views)
I could not open your project because I'm using LV 2012. You can expand the graph legend and hide the red line, but I'm guessing there is a deeper problem with your code if you can't figure why it is plotting 2 lines instead of 1.
(5,067 Views)
In the subVI where you create the notification, you are acquiring "N sampes,N Channels", Maybe you have it configured for 2 channels?
(sorry, I don't have DAQmx installed, so I cannot look at it in detail)
(5,013 Views)
It seems like I created the same task twice. If I allow the user to select a DAQmx task created in MAX in the Settings dialog, is there really any purpose for Initialize Hardware References.vi?
(5,000 Views)
Congratulations -- this is one of the nicest pieces of code I've encountered on the Forum over the past several months.  Thank you for organizing it in a Project (although "Untitled Project 2" lacks imagination), and also thank you for including the entire Project.
You use the Hardware Configuration Cluster (kudos, as well, for TypeDef-ing all of your Clusters), so if you do not initialize it somewhere, you won't have a Task to reference!  However, since you are using LabVIEW Project, you might consider defining the Tasks inside the Project, rather than in MAX.  To do this, right-click "My Computer" in the Project Explorer, choose New, then New Task.  It will open a MAX-like window where you configure the Task.  This Task will appear as a Drop-down option on your Task Constant, using a slightly different Icon to distinguish it from a MAX-defined Task.
Hmm -- I just re-read your question.  What do you mean by "the Settings dialog"?  Was that something I missed?  [Probable answer -- yes, Bob, you missed it ...].
Bob Schor
(4,991 Views)
Hi Bob,
Please see the attached screenshots. The first one is the Settings Dialog vi. It seems I can load the task I have defined there, or in Initialize Hardware References.vi.
Currently my Settings Dialog.vi is what is shown, and I have removed the "Task to Copy" input of DAQmx Create Task.vi. This seems to have removed the double plots.
Also I will definitely get around to defining Tasks in the Project if it is recommended.
Much thanks,
Ben
(4,984 Views)
