LabView RT FTP file size limit
I have created a few very large AVI video clips on my PXIe-8135RT (LabView RT 2014).  When i try to download these from the controller's drive to a host laptop (Windows 7) with FileZilla, the transfer stops at 1GB (The file size is actually 10GB).
What's going on?  The file appears to be created correctly and I can even use AVI2 Open and AVI2 Get Info to see that the video file contains the frames I stored.  Reading up about LVRT, there is nothing but older information which claim the file size limit is 4GB, yet the file was created at 10GB using the AVI2 VIs.
Robert
(3,329 Views)
As usual, the answer was staring me right in the face.  FileZilla was reporting the size in an odd manner and the file was actually 1GB.  The vi I used was failing.  After fixing it, it failed at 2GB with error -1074395965 (AVI max file size reached).
(3,324 Views)
