LabView Runtime...
We have developed projects in LabVIEW 2017 and are currently migrating to Windows 11, but we still have some machines running Windows 10. I found and installed LabView runtimes compatible with Windows 10 and Windows 11, but when we launch our projects, LabVIEW tells us that the runtimes are not installed... .
Could you please send me download links for LabVIEW 2017 runtimes compatible with Windows 10 and Windows 11?
Thank you
(753 Views)
Thank you
you get all LabVIEW Runtime Versions from
https://www.ni.com/en/support/downloads/software-products/download.labview-runtime.html?srsltid=AfmB...
after a login.
LabVIEW Runtime 2017 supports Windows10, Windows11 is not officially supported, but may work.
(735 Views)
One thing to double check is which bit-ness your run-time engine is.  An application might claim it needs "Runtime 2017" or something, but there's both 32 and 64 bit versions of that.  Install the other one if it complains about missing one when you have definitely installed it.
(670 Views)
Thank you, i'am going to check it
(460 Views)
