LabView Test Q2 please someone help
When Should Tasks be used in a DAQmx Application
A.  If you want to perform channel acquistion in a distinct order.
B  if you want to sample channels with similar scaling.
C. If you want to sample channels witrh similar timing and triggering.
D  none of the above.
(3,364 Views)
see here
(3,344 Views)
We should really keep these questions to one thread. For the linked thread however, it may be better to ask specific questions on where to find information on each question rather than the just to ask the question straight from the test. It is important if you are taking a test to understand the concepts. For example the information for this answer can be found in this Task Info  ( just look at what information is carried in a task line). This forum will not help you answer questions to test directly (ie The answer is G), but it can help you find the information that you are looking for and help you understand LabVIEW.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(3,303 Views)
