LabView (VI Tester) Supports Junit
Hi All,
Labview - VI Tester whether its supports Junit or not.
If supports how to write the test case in VI Tester
Ashok Sridharan
Bangalore, India
(2,837 Views)
Ashok,
what do you mean by "LabVIEW VI Tester"?
There is toolkit available called "Unit Test Framework" as LV does not interact with JUnit (that is only for Java code).
Norbert
Norbert
Expert: Geometry
(2,823 Views)
