LabView and dll
is it true that only Labview 6i can make dll's? Because I have Labview 5.1
and need dlls to give info to Visual C++...
Thx,
Bull's
(3,134 Views)
Yes, I think this is true.
Oleg Chutko.
(3,134 Views)
Yes, it is true. You need the application builder. Just like building an executable, instead, you select to build DLL. Fairly easy to use. But I suggest using simple data structures (arrays and scalers), clusters should be avoided if you can.
Joe
(3,134 Views)
