LabView code for Allan Variance?
Is there a LabVIEW tool for Allan Variance?
Message 1 of 30
(13,467 Views)
There is no single VI that computes Allan Variance, but you can definitely code it yourself using Analysis VIs (under All Functions -> Analyze -> Mathematics -> Probability and Statistics and others).
Thanks and have a great day!
Shakhina Pulatova
Message 2 of 30
(13,432 Views)
You will find a library called Allan_Statistics.llb
under (NI path):
NI Home > NI Developer Zone > Development Library > Measurement and Automation Software > LabVIEW > Development System > Fundamentals > Graphs and Charts
or (URL):
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=EF32F4D54B4A211CE0340003BA230ECF&p_node=DZ52028&p_source=external
Have fun - any feedback to the author about the usefulness of this tool is appreciated!
Message 3 of 30
(13,393 Views)
Anyone care to send me images (screen capture) of the Allan variance code found at the url given above?  I'm using LabVIEW 6i (6.0.2?) and can't open it...  I'll contact the author if this is going to take too much effort - it's been a few years since he posted though.
Message 4 of 30
(13,167 Views)
Hi suetheche...,
here it comes in LV6.0. I just converted the actual calculation vi and change the comments from German to English.
Message 5 of 30
(13,162 Views)
I never did get round to saying thank you GerdW - so thankyou!Smiley Happy
Haven't had a chance to try it out yet either, but it was much appreciated.
I'm suethecheMIST by the way, but I quite like suetheche, has a ring to it!
Message 6 of 30
(13,124 Views)
I reworked this code and tested it against Stable 32.
Message 7 of 30
(12,993 Views)
Here's some pictures of the VI's.
Message 8 of 30
(12,992 Views)
Message 9 of 30
(12,982 Views)
Hi Subliminal,
you should really clean up your code before uploadingSmiley Wink
I just changed 2 of those vis (allan-variance-dynamic.vi and calc_allan-variance.vi), the rest is up to you! (removing sequences, especially the stacked ones!; removing unneeded for loops, unneeded operations like deleting twice the first element, replacing constant math operations by constants - even when LV8+ is optimizing them anyway)
Message 10 of 30
(12,960 Views)
