LabView code module to perform simple pass/fail *IDN? query?
LabView 7.1, TestStand 3.1, NI PCIGPIB board controlling a communications service monitor and a power supply. I'm having problems with my application sync correctly between the service monitor and GPIB board. I suspect the driver. Does anyone have a simple LabView code module to perform a *IDN? with a partial (in case they change firmware versions)string comparison that I can use in a TestStand seq. At this point if failure I could pop-up and tell operator to abort test and reboot instrument. (only way I've found to clear the buffer). Note: At times this app works fine and is inconsistant in failure times/rates.
Sorry so wordy and thanks in advance.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,431 Views)
GovBob,
The best example to use for simple GPIB communication can be found in the shipping examples that come with LabVIEW. The example I am referring to is called 'LabVIEW<->GPIB.vi' and can be found by using the NI Example Finder. With regards to the TestStand portion of you question I would recommend posting to the TestStand message board for better response. Hope that helps!
Craig H.
NI Applications Engineering
(3,407 Views)
Thanks for the reply Craig.
I've found I can perform a *IDN? using the Instrument I/O Assistant.vi. Ive placed this on a new block diagram and am changing it as I need. I've found in this particular case the *IDN? yields 3 tokens one of which I can use to perform a string comparison on. This will give me a boolean which I can wire to the pane for use by TestStand.
(3,394 Views)
