LabView control
I have got a PCI 6024E.
I would know where i can find a VI which allows me to manage a tension
output between 0-10 V.
Thanks Perseo.
(3,835 Views)
Hello;
If, in Labview, you go to Search Examples->I/O Interfaces->Data Acquisition->Analog Input->Continuous Analog Input; you will find some good examples showing how to do Analog Input tasks.
You can get start with the one named Continuous Acquisition and Chart (buffered).vi.
Hope this helps.
Filipe
(3,835 Views)
Filipe wrote in message news:<50650000000500000001650000-1012609683000@exchange.ni.com>...
> Hello;
> (buffered).vi.
> Hope this helps.
> Filipe
Thanks, now it works.
But now I would like to avoid the NI board. I've a DSP cheaply
connected by a parallel port. LabView could manage it? And if I would
to buy a D/A chip could I interface it (by serial port)?
Thank you, Perseo.
(3,835 Views)
You have a lot of seemingly non-related questions.
Perhaps it is in your interrest to tell the forum about your real needs.
(3,835 Views)
PdB_Serenity_nl wrote in message news:<506500000005000000BC650000-1012609683000@exchange.ni.com>...
> needs.
Yes, you're right, pardon me.
I want to avoid the PCI now.
So if I want to manage a voltage 0-10 V, by the computer I need to employ a DAC.
I found DAC714 (TI), which is interfaced by the serial port.
Is possible to comunicate to it by labview?
Is it necessary a driver for the Handshaking?
Or is all managed by labview?
(3,835 Views)
I briefly read the datasheet of the DAC714, a 16 bits DAC device. Sorry but the serial input is not intended for connection to the RS-232 port. It is designed to connnect to a micro-controller/processor.
You then enter the world of electronics design.
I hope you/your company has that expertise.
My company has this knowledge and we have developed several micro-controller applications that talk to similar peripherals and communicate with a LabVIEW application via the RS-232 bus.
Perhaps an of-the-shelf low-cost serial DAQ-device is cheaper.
(3,835 Views)
PdB_Serenity_nl wrote in message news:<50650000000500000045680000-1012609683000@exchange.ni.com>...
Where may I find it?
(3,835 Views)
