LabView equivalent to Visual Studio FormClosing
In Visual Studio there is the method FormClosing which lets you perform some actions when the CloseWindow icon is pressed and before the application closes
Is there an equivalent way to achieve the same in LabView ? I want to close an instrument connection and some other housekeeping actions if the operator presses the Close Windows icon.
David DLC
(2,660 Views)
Use a "panel close?" filtering event. Discard if necessary, then close by other means once all shutdown code has completed.
(2,649 Views)
