LabView ethernet communication
Hi, I would like to use LabView to communicate between a pc and network attached storage device via ethernet. How can I do that. Do I have to just write the code for some ethernet communication or is there anything else.
(3,262 Views)
I would just map the drive through Windows and then you just use the standard file I/O functions.
(3,257 Views)
