LabView hangs when trying to load the same VI with a different user logged onto Win2k
When 'User A' is logged onto Win2k, a particular VI loads and runs fine. When 'User B' logs onto the same Win2k box, LabView hangs when trying to load the VI.
I'm also not seeing the setup channels in the Data Neighborhood in MAX when logged on as 'User B'. I tried loading the configuration when logged on as 'User B' that I think is being used for 'User A', but nothing happens.
Where are the configuration files (of whatever type) that tell LabView which user is logged on?
Thank you!
(2,555 Views)
There are no configuration files that tells LabVIEW what users are logged on. It is Win2K permissions settings that allow different users access to different folders and applications. Try changing the permissions for the LabVIEW folder and see if that doesn't fix your problem.
(2,555 Views)
