LabView help won't open
I have been trying to open the search LabView help and the help won't open.  A window appears but then it won't load.  I haven't done anything different to my computer, this just started happening suddenly.  The whole program then usually crashes when I try to close the help after a while.
Any ideas?
Message Edited by flyer88 on 01-28-2009 03:29 PM
(3,811 Views)
Does this happen no matter when you try to open LabVIEW help? Even if you click the LabVIEW Help button on the Getting Started page?
Does Context Help (Help >> Show Context Help) still work?
What version of LabVIEW are you using?
Also, can you open LabVIEW Help or any other help file externally? LabVIEW Help can be found in Program Files >> National Instruments >> LabVIEW x.x
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(3,779 Views)
---This is what I was doing.
--The start menu help does seem to work.  However, this makes looking things up while programming difficult.
--there is a help folder....full of files and such.  I can't see where I would launch the help from.
(3,774 Views)
Since the help files are functional, but the implementation of Context Help seems to be corrupted, I would suggest repairing LabVIEW. Take a look at this KnowledgeBase for instructions on how to do that:
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
Will
LabVIEW Champion
choose-mc.com
(3,753 Views)
