LabView installation error--
I am trying to install LabView 7.1 and I just cannot proceed. Any help will be appreciated.
Following is the error message:
____________________________________________
K:\NIInstallers\trunk\1.2\src\UberInstaller\ConfigInfo.cpp(2371): IInstallerError 11005
Fatal Error. Unable to find initialization file.
File J:\setup.ini not found.
Exception code: E06D7363 ()
Fault address: 77E34B5B 0001:00003B5B K:\Windows\system32\kernel32.dll
Registers:
EAX:0012F8AC
EBX:0093C401
ECX:00000000
EDX:00931B68
ESI:0012F93C
EDI:0012F93C
CS:EIP:16001B77E34B5B
SS:ESP:77F300230012F8A8 EBP:0012F8FC
DS:80000023 ES:0023 FS:16003B GS:160000
Flags:00000206
Stack Trace
Address Frame LogicalAddr Module SymbolName + Offset
77E34B5B 0012F8FC 0001:00003B5B K:\Windows\system32\kernel32.dll RaiseException + 60
004D0E5F 0012F93C 0001:000CFE5F J:\setup.exe
00411BB7 0012FA40 0001:00010BB7 J:\setup.exe
00408D1F 0012FB70 0001:00007D1F J:\setup.exe
77D0C2D9 0012FC08 0001:0002B2D9 K:\Windows\system32\USER32.dll LoadStringA + 28
7188DA1E 0012FC30 0001:0000CA1E K:\Windows\system32\UxTheme.dll GetThemeBitmap + 1003
77CFFC49 0012FC34 0001:0001EC49 K:\Windows\system32\USER32.dll PtInRect + 682
77CFFC32 77CFFC49 0001:0001EC32 K:\Windows\system32\USER32.dll PtInRect + 659
90909090 77CFFC4D 0000:00000000
8868086A 77CFFC51 0000:00000000
E877CFFC 77CFFC55 0000:00000000
FFFFD6F3 77CFFC59 0000:00000000
00FC6583 77CFFC5D 0000:00000000
FF08458B 77CFFC61 0000:00000000
(8,014 Views)
Are you trying to install from a file on J: (drive)? or is that the drive id for your CD-ROM?
It appears to be installing from the root directory of J:    And obviously missing the file "setup.ini".
Is it a CD-ROM, if so, is there a file called setup.ini?  If there is, can you open it using Notepad?
If it is a file, then you may need the missing file.
JLV
(8,008 Views)
