LabView programming
Example LabView code &/or VI's for LCUS-1 type USB relay module.would be great. In addition, are there LabView drivers for this device ?
(2,293 Views)
Do you have a manual? Have you read it?
Since you did  not provide a link for the "LCUS-1 type USB relay module" I did a quick google search. According to a user on Amazon, it is a simple serial port. Take a look at the "Continuous Serial Write and Read.vi" in the examples to get you started
<C:\Program Files (x86)\National Instruments\LabVIEW 20XX\examples\Instrument IO\Serial\>
Former Certified LabVIEW Developer (CLD)
(2,243 Views)
