LabView report generation Toolkit-word
I'm facing an issue while generating a report showing this error:
Error -2146822307 occurred at Unknown System Error in
NI_ ReportGeneration Toolkit.Ivlib:Word_Create_Document.vi-> NI_Word.Ivclass:
new report subVI.vi-> NI_report.Ivclass:New Report.vi-> FD Generate Report Summary.vi-> REPORTS ANALYSIS.vi-> Force Testing Software.vi
(1,491 Views)
The Report Generation Toolkit relies, in part, on software that NI does not control, for example, Microsoft Word and Microsoft Excel.  Periodically, Microsoft "adds a Feature" that throws errors in the RGT of the type you describe, and one of us tracks it down and reports the Fix in the Forums.  Try doing a search (use the Search bar on the first page of the Forum) and see if you find your problem described and (I hope) fixed -- if so, please tell us where you found the fix (to help others with the same issue).
Bob Schor
(1,446 Views)
Follow the steps(screenshots attached) to update in ActiveX Settings
File -> Options -> Trust Center -> Trust Center Settings ->
ActiveX Settings
(234 Views)
